Turboed Corolla Overbuilt?
MN: ZZE122R
Engine: 1ZZ-FE
I'm currently in the final stages of researching about boosting my car which I'm finding is incredibly expensive but oh well car people aren't sensible people. I was looking to make this car a sort of daily but take it to the track and car meets. Anyways I was just looking around at other forums and I couldn't find any that described the type of mods required for a certain power level as I don't want to spend a heap of money when I don't need to however I want to make it kinda reliable so idk. My power goals are between 275-350hp running E85, here are the engine internals I want to upgrade:
  • Monkey Wrench Racing (MWR) 1ZZ-FE Engine Rebuild - Forged Rods, ARP Main and Head Studs, Ported, Upgraded valves, stock 10:1 CR
  • Turbo - GTX2860R
  • Fueling - MWR Injectors 630cc, AEM fuel Pump 340lph, (might do flex fuel),
  • Intake - Billet Centre fed intake, Haltech DBW conversion
  • Boost control - (I'm not too sure what to buy)
  • Intercooler - (Anything that'll fit)
I hope I wasn't too vague, I was asking a tuner in my area called Tunehouse (lovely people btw) and all they said was you might have to run a bit of boost so I'm not too sure how to interpret that in this context. Any advice will help, thanks.
      New member
    2. 7
      Rear power door
      Stereo upgrade
    5. 8
      2ZR Turbo
    6. 7
      Rear power door
      Snapping wheel and axle studs
      Fuel filter change - start stops running
    9. 17
      Wobble at the front
    10. 7
      Brake issues
