PEOPLE ON TOCAU !!
476 members have voted
Ln167 crankshaft damage what are my opinions
Hello I'm looking for help with my 1998 toyota hilux ln167 3L diesel with the 5L motor as i started to notice a knocking noise after I did a 4wd trip and found out it was a the harmonic balancer as I was taking it off the harmonic balancer was really wore in the key way and the same on the shaft of the crankshaft, do I need a new crankshaft? Crankshaft https://photos.app.goo.gl/GHoXsXsdCJeDsNrz8 Harmonic balancer https://photos.app.goo.gl/9iUKALStsVjWZyzX7 -
iPhone intermittently connects to CarPlay or visa versa?!
So I have changed out multiple cables. I don’t believe it’s the phone but rather the cars electronics? I plug the usb into the port near handbrake middle console. sometimes Apple CarPlay comes up and others not . Phone is being charged so a connection is occurring electrically. ideas ? cheers -
Gents, I want to narrow down possible cause, as I'm not a pro... - I can lock/unlock all 4 doors with key. - I can LOCK all doors with fob, when unlocking with fob, driver's doors stays locked. I found the small plastic hatch on door panel which moves when you lock/unlock doors wont move properly when locking/unlocking. Is this likely to be a mechanical issue? Should I just put some grease on cords inside the doors? Or issue could be with locking actuator? Thanks for replies! Cheers. Martin -
2004 camry ventalation cables
hi need to out new bulbs in my base model ascent camry hvac controls box how do i remove the cables at the back of the box to get access to the bulb holders to change bulbs -
indicators /hazard /central locking lights stop working
can anyone help my indicators / hazard lights / central door locking lights just stop working . i was told it could be the flasher relay so ive changed it it worked for a day and now its gone again this time the hazard lights / central locking and only the right hand indicators works any suggestions by anyone -
5
Adding driving lights into a Toyota Hybrid (Kluger)
Hi, I have 2021 Toyota Kluger Hybrid. Did you have any problems mounting driving lights?? That is; did they effect the sensor (that is mounted within Toyota logos on front of car) Thanks Mark -
KUN26 SR5 help mounting sport bar and 3 piece lid
https://toyotamanuals.com.au/accessories download it as PDF works on any accessories -
6
