SuperDave's Sled
SuperDave
  • 6 months later...
  • Replies 78
  • Created
  • Last Reply
Top Posters In This Topic
Yearly update.
Snapped a valve.
Bent the valve and cracked the valve guide.
Finished rebuilding it the other day and now it has flat faced valves and stiffer springs. The exhaust valve seats were pitted which was giving low 180PSI readings, and after grinding the seats it is back up to 200-205PSI. 180PSI is still well within the Toyota Sepcs too. MWR claim the flat faced valves add about 0.3:1 to the compression ratio, which should be about 5PSI by my dodgy maths.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
