Caliper Question
hi all,
just wondering does anyone know about the sportivo caliper, are they single piston or twin piston? and whats the disc diameter
coz im thinking changing mine to either a supra one or a TRD caliper.
thanks all
cheers :)
Welcome to the Forum daonlyhata, to my knowledge...
Sportivo Brakes:
Front
275mm Ventilated discs with two piston calipers
Rear
279mm Ventilated discs with single piston calipers
Cheers ;)
They are solid discs at the back. 1zz: 2 pot front calippers? are you sure dude, that sounds a little exotic for a 30k car, although i must say they are great brakes.
Extract from carsales.com.au
TOYOTA COROLLA ZZE122R SPORTIVO
Front brake description
Ventilated discs
ABS - number of channels
Rear brake description
Discs
Front - diameter (mm)
275
Rear - diameter (mm)
279
Oh, BTW, just had the 30k service, (and after the mechanic originally told me the Stivos had a harder fromt pad,hence the disc warp) they tell me i have 5to10,000 left on the pads!! I believe a firm pad should do 60,000+ km.
Pecker, keep us posted as to a direct Toyota replacement, as I'm dead keen.
I recentley priced an AP setup, but at 3.5K for the job, is a bit pricey :o
