Hi there,
I just bought this from ebay and all there is on the installation guide was
Installation consists of a two wire hook up...Just connect the red wire to any 12-16 volt DC positive voltage source and the black wire to ground. You can hook them up to a switch to turn them on and off when you want, or wire them into your headlight wiring so they turn on when you turn your headlights on
which wouldnt mean nething to a person that dont know his wiring/electrical tht well (well thts me)
I was thinking that I would like to wire it up to the lights on top (the light tht turns on when u open ur door) so everytime i open my door the LED lights up but problem is i dont know where all the wire is and if i changed my mind on wiring it to the door lights and just decided to just use a switch to control it. I was just wondering where should i connect it to (where bouts are the wires and stuff)
**i did take out the ciggy lighter bit and had a look @ the wiring - is on of the wire on there the ignition wire and another one is ground wire?
Thanks you so much for your help :) Im still learning and hopefully next time :) i can start helping instead of askin for help :)
Kenneth
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
