It would serve no purpose Bec as Dyno readings are not indicative of the real world. They are a tuning tool only. If we were to compare power output of cars you need to look at all the cars on the same Dyno on the same day and even then there will be differences when comparing the 1st runner to the last runner.
The best way to compare output is to look at trap speed at the track, hence why we ask for the entire slip, not just the time.
Oh, but it would allow one person to say that his di^^$@ is bigger than the other persons because he has more hp !!!!!
:whistling:
I am for it.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
