Hi Ive got a late 2002 Camry, I entered the sec menu on the radio/cd to cancel the security code so I could turn off the pwer to the radio. Unfortunately for some reason the security code is not being accepted. I only have 4 more tries. How do I get out of this mess. Thanks Ian :(
hmmm are u sure the security code is correct?
If not it should be in your manual/warrenty info otherwise give the dealer u bought it from a call, they should be able to help u out with the code itself and the procedures for entering it
Yes I'm afraid thats the only option. The code I thought was it is incorrect. No point trying it again and again until it totally locks. I would be quite happy to have the sequence to just have it back to where it was! :help:
is it 3 or 4 digits?
try last number of the vin number or the dealer 3 number code... always a possibility.
or just call em :lol:
When I bought the car the radio did not have the security code activated. I activated it by using the code in users manual. Well thats what I thought anyway, now that 3 number code is not un activating it. So Ive blown it! :(
All well that ends well. Overnight the radion started up as if nothing had happened. Phew. :P
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
