[WA] WaynO's Dark & Dangerous Cruise
Rear speakers?
Hi all, newbie here with a 2020 4x2 Hilux Workmate Facelift. A few things please. 1. There are grilles for speakers in the rear door panels, but no sound when adjusting the equaliser. I guess there are no speakers behind the grille. Am i right? How easy is it to remove the door panel to fit speakers please? 2. Does the sound unit have an anti theft code that i need to reset if i have to disconnect the battery at some time? Thanks. -
Petrol Jerry Can storage?
Hi. How and where can I store a petrol jerry can, and water, on a my Kluger hybrid 2024? Thanks. -
Seca AE92R owner's manual
Hi, do a search "seca 1993 ae92r user manual", quite a few, for sale, pop up. Herb -
I recently purchased an unregistered Seca 1993 AE92R and it did not come with an owner's manual. Would someone be able to share their owner manual with me in an attached pdf please? -
7
Fuel usage
I bought recently a toyota rav4 2024 - XLE regular- and i get on long drives under 7 liters per 100 km, sometimes 6.5 liters per 100 km. But for the first half of the drive the gas mileage is around 8 liters per 100 km. Do you have similar gas mileage? -
Cruise Control Not Engaging
Got the same issue on my 2005. I am wondering if it's to do with the airbag recall replacement. Might have not been reconnected, or the clock spring doesn't support cruise control. I will have to make time to pull the airbag off and see whether it's visually obvious. -
Toyota Coaster 1992 BB21R Service Manual (need one)
Hi, I'm new here so not sure what help I can get... I need a new radiator for my Toyota Coaster BB21R but can't find one anywhere, any ideas? Also, I would like a service manual if there is one available (can't find that either). Thanks, John 0418 315 911 -
1993 Corolla Seca CSI limited
Could I please get a copy of the owner's manual that came with this car? I recently purchased the same car unregistered but it came with no owner's manual. Happy to pay for photocopying and postage. Or could you please tell me the part number that is inside the owners manual so I can try and find one on ebay. Many thanks -
15
Connecting spotlights to high beam on 2011 Hilux
Conrod. Thanks for this info. I spent about an hour trying to get my brain around this. Your solution worked perfectly.- 1
