rays lock nut on kappa's
master.Cuong
I'm pretty sure that Rays nuts will fit any sort of aftermarket rim. It's to do with the lug nut seat type/angle.
But to answer your main question, I'm unsure if the Kappas will take 'tuner' lugs. :)
The Kappa's require the shank-style lug nuts as per the image below (just with a longer head), so as long as you can find shank-style lock nuts, you would be fine.
      Drive shafts
    2. 0
      FUSE BOXES ALLOCATION - 1996 SUPER CUSTOM Model (Import)
    3. 10
      Vibration through body (not steering wheel) under acceleration
    4. 0
      possible fit 2015 kluger Grnde driver seat on 2019 kluger GX
      front brake calipers
    6. 1
      Drive shafts
    7. 315
    8. 10
      P0420 Catalystic converter below Thrushold
    10. 0
      Dashlight dimmer
