STAINLESS STEEL overflow tank
I noted from a previous thread that the plastic overflow tanks are prone to cracking and on inspecting mine found it to be cracked across the top. My car is a 1999 model Camry-Vienta. Does anyone know if there is an after market stainless steel tank available for these cars. Replacement should be easy as there appears to be just one bolt holding it in place plus the rubber tube.
Edited by peregrine
Not as a part made to be a direct fitting replacement for the current overflow tank that you have. You would need to find either a generic aftermarket replacement or one made for another car that has similar dimensions to what you require.
      Gen 6 Cluster Backlighting Issues
      Hilux surf
    3. 6
      Buying a Hilux / Surf
      05 hiace ecu
      1989 Hilux Low Voltage
    6. 27
      FUEL WARNING MESSAGE
    7. 27
    8. 27
      Wanting to build my car.
      2004 hzj79 surging/jolting
