Posted (edited)
Hi everyone,
im trying to install Dvd headrest and i need to run the wires through the headrest holes.
to do that i need to remove the back plastic in the front seats but i cant figure out how to remove the plastic with out breaking.
i have the sportivo model whichi think is different to the ATX, prodigy and presara.
can anyone help?
thanks
Edited by Bruster
Try following this. You basically remove the two screws from the bottom (don't say you can't find them) and then everything slides down, which is easier said than done.
Hi everyone,
can anyone help?
thanks
Hi
I have an Aurion ATX and have done the head rest dvd conversion on this model all there is if you look at the bottom of the seat you will see carpet it is simple to remove all you need do is reach under the seat and it has elastic holding it unclip it and it will reveal 2 screws that you need to remove then its just a simple pull the plastic of the map pockets downwards and its done . not too sure if the sportivo is the same . Hope this helps
thanks DJKOR, i was searching for ages...youtube, toyotanation,google...couldnt find anything.
i'll take my hat off to you.
thanks TRDcelica.. i will give it ago tomorrow night after work..
see how i go.
      Tyre Sale Specials
    2. 0
      overheated engine
    3. 1
    4. 62
    5. 1
    6. 1
    7. 1
      Tyre Sale Specials
    8. 10
      Android auto
    10. 0
      Remote start
