Nice lowering man! There are sort of plastic plates that you can install between the rim and the attack of the disc and with those "plates" you can change the rear camber. Like these Camber shims
Hey what's up! Just joined the forum.I am from the caribbean. You've done some nice stuff on the 3zzfe. I also have one, just a CAI and 2'' exhaust without cat converter so far. Parts limited on this side. Are u running auto or manual?
I have a Camcon on my VVT-i engine. It's a piggyback ecu, it work togheter with the stock ecu. Camcon allow you to set the camshaft degrees and the % of airfuel injection. You must be able to find the right balance to obtain a linear power and torque graph.
Thank you mate :D
Next work in program are new exhaust manifolds, I don't know if new ones like TRD or whether to work the stock ones.
I want also install a decent front end links for an optimal track day work of the adjustable swaybars.
In my erotic dreams there's a turbo conversion.
