Bridgestone Turanza T001 vs Michelin Primacy LC?
TRD Front Strut Brace to suit ZZE122/ZZE123
1 x Used original grey TRD Front Strut Brace to suit ZZE122/ZZE123 (Discontinued years ago – rare): In excellent condition for age, minor cosmetic issues near bolts. Advertised elsewhere as well. AUD$420 Cash pick up only NO OFFERS PLEASE– located in Elanora Qld 4221. I have repair kits for the centre console door available also- oem
- strut brace
(and 3 more)
Tagged with:
H7 12V 55W Replacement - No Retaining Clip
Hi all, I lost the hi beams retaining clip for the hi beams bulbs on my Toyota, is there a replacement that I could get that doesn’t need that retaining clip? will take any help. The stock bulb for my vehicle is below.- 2004 toyota corolla
- toyota allex
(and 1 more)
Tagged with:
ST-162 front door-glass seal availability
Hi all, my wife has a 1988 ST-162 Celica which I have been lovingly caring for since we met 25 years ago. It is in VGC, but of late the wind noise at freeway speeds has become much louder, and with the current wet weather the front doors are leaking rain through the 'seal' point between the window glass and the door seals. The doors are hanging in the proper position and the windows do not seem to be unduly loose in their carriers. I am trying to find a new set of door seals to try to fix the problem, but have had no success anywhere. Any ideas or suggestions would be most appreciated! My mobile is 0427 478874, or reply here! -
It was done right 5 months ago.. ok… Now I am even more scared.. cuz it was done by Toyota Service Centre.. they replaced both brake pads.. 😖😖 -
Not sure how many of the old guard are still around… fluids drained, fuel tank cleaned and lines purged, might be time to throw it into gear again.- 1
Need Advice please
Suggest that you look at an online catalogue for struts/shock absorbers specifically for the Year and Model specification for your Camry. Easiest way to clean fuel injectors is to use a fuel additive together with decent quality fuel. -
For starters, you are referring to the BRAKE calipers. Missing bolts is highly probable that whoever last worked on the braking system did not properly tighten the bolts to the correct torque specification. Presumably, the brake pads were replaced approximately 6 months ago. -
Hi All, I have sent my car to a local mechanism shop as I heard a big scary clunk noise from the front left wheel part recently. And a huge surprise came back to me is, they told me that my break calipers has two bolts missing. I don’t think it is a common problem caused by daily routine driving. So really need to find out what was happened to that 2 bolts?! How lucky I was for driving nearly half a year without a tight break!! I even have kids on my car… can’t think more now. It’s terrifying 😱 -
10
Engine Immobiliser
Hi Chris, I would suggest getting a code scan as well mate as it could be something locking out the security starting process, and it may make tracking it down faster for you maybe worth the fee for a mobile mechanic who can do that for you as I doubt it will be a fuse or relay causing it sounds,like something in the security side of the process. I am sure if any others have ideas they will post it, these are just guesses on my part so I hope you get it sorted fast mate KAA -
Hello Toyota Club AU
Welcome to the forum Dan, I hope you can find your answers for your Yaris KAA
