Throttle bodys
rollagrl
:unsure: has any body put a bigger throttle body on? or even quads? :unsure:
I have searched everywhere for quad throttle bodies for the 2zz. One company in the US used to manufactured one for a short while but no longer offer them due to the difficulties in fitting. The problems were associated with space. I am sure with the right money you could get something custom.
Rollagrl we did some resarch in to this (Stuart and I) and aprt from doing a 4 throttle body conversion there is no benefit the Japs got it right. We had vaious tests done and were advised against it the testing cost us a few hundred dollars. So I would forget about it. Simply put if it was worth while we would have done it already.
oh well, i could just spend the cash on other things..... :( so wat ur sayin is quads would be ok but a larger single would be no good? pls explain :) me confused.... :huh:
Edited by rollagrl
Um where shall I start there is plenty to do ...I worked out the other day so far I have spent at the very least 11,000 in mods so far and ahhh still have a few more to do.. IE Oil Pump, LSD, Valves and Pistons now if you have a spare 6 grand you aren't doing any thing with please give it to me... :P
if i had 6 grand spare peekay id a, put better brakes on the front, sway bars strut tower braces.... now shocks and springs so i can drop it another inch... and afta it stops and handles better any left would go 2 the motor.......... can i borrow 20k peekay? pls? :D :P
I went to a place that is called EFI hardware, that is primarily what they do EFI Systems for cars. They did vaious tests as we wanted to see if it was worth while doing a mod to make the body larger. They said it would be a waste of money. Quad bodys would just be more responsive but would cost thousands to do. If you read the USA forums they have not really done anything with the throttle body and they have cheaper and easier access to parts than we do, so that should give you some indication.
And ahh sorry no 20K
      1kzte throttle body
    4. 3
    5. 5
    6. 5
    7. 8
      PZQ60-00525 Issue
    10. 3
      Head Unit with Apple CarPlay
