The Japanese MR2's came out with the Manual Transmission standard... From memory it's only a 5 speed tho...
I'm guessing you'll need:
Gearbox
Flywheel
Clutch
Shafts (might be interchangable)
Cables
Shifter
That should be about it, not too sure tho... Would have to speak to the experts...
you need the shift linkages and mechanism off an MR2 C series gearbox, then you modify the celica or corolla box to accept the 5-speed's shift linkage setup. It's been detailed on MR2OC etc.
just source all the parts from the later car then
hi just wondering
is the mr2 the same as the mrs? the zzw30r?
i got a 2zz-ge&gears from an 05 sportvio n was wondering if its easy fit on the mr2.
or would it b easy to convert my 05 sportivo to my sister 05 1zz corolla automatic?
  • 8 months later...
Guest fujiwara_tofu
mr2 = aw11 and sw20
mrS = the newest one
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
