Post UR CAI pics here pls! - cold air intake??
Ln167 crankshaft damage what are my opinions
Hello I'm looking for help with my 1998 toyota hilux ln167 3L diesel with the 5L motor as i started to notice a knocking noise after I did a 4wd trip and found out it was a the harmonic balancer as I was taking it off the harmonic balancer was really wore in the key way and the same on the shaft of the crankshaft, do I need a new crankshaft? Crankshaft https://photos.app.goo.gl/GHoXsXsdCJeDsNrz8 Harmonic balancer https://photos.app.goo.gl/9iUKALStsVjWZyzX7 -
iPhone intermittently connects to CarPlay or visa versa?!
So I have changed out multiple cables. I don’t believe it’s the phone but rather the cars electronics? I plug the usb into the port near handbrake middle console. sometimes Apple CarPlay comes up and others not . Phone is being charged so a connection is occurring electrically. ideas ? cheers -
Gents, I want to narrow down possible cause, as I'm not a pro... - I can lock/unlock all 4 doors with key. - I can LOCK all doors with fob, when unlocking with fob, driver's doors stays locked. I found the small plastic hatch on door panel which moves when you lock/unlock doors wont move properly when locking/unlocking. Is this likely to be a mechanical issue? Should I just put some grease on cords inside the doors? Or issue could be with locking actuator? Thanks for replies! Cheers. Martin -
2004 camry ventalation cables
hi need to out new bulbs in my base model ascent camry hvac controls box how do i remove the cables at the back of the box to get access to the bulb holders to change bulbs -
indicators /hazard /central locking lights stop working
can anyone help my indicators / hazard lights / central door locking lights just stop working . i was told it could be the flasher relay so ive changed it it worked for a day and now its gone again this time the hazard lights / central locking and only the right hand indicators works any suggestions by anyone -
5
Adding driving lights into a Toyota Hybrid (Kluger)
Hi, I have 2021 Toyota Kluger Hybrid. Did you have any problems mounting driving lights?? That is; did they effect the sensor (that is mounted within Toyota logos on front of car) Thanks Mark -
KUN26 SR5 help mounting sport bar and 3 piece lid
https://toyotamanuals.com.au/accessories download it as PDF works on any accessories -
6
