Twin-charger idea...
DuGong
Supposed i want to twin-charge my car with supercharger and turbo and i have reinforced all my internal and the car is manual...
will twin-charging work if ... i think(not sure) BEE-R S15 twin charger works like this....
air => Filter => turbo => intercooler => supercharger => engine => turbo => exhaust => >??? running power-fc...
i read some other site about twin-charging ; this is how they demonstrate it from my understanding..
air => Filter => turbo => supercharger => intercooler => engine => turbo => exhaust => >???
does it matter where the intercooler goes???
That looks the same as the BrashBoys setup if I remember correctly Billy, complete with bypass
i think so ..... i had a write up somewhere about the brashboys setup ..... however for $24K i think they can keep it ;) ;) ;) (and that excludes the engine internals and other bits u'll need to run their kit)
but u knw if anyone is keen i would be more than happy to see the results as there isnt much available about the brashboys setup ..... ive seen 2 vids and in both it sounded insane but he was only driving it "mildly" ...... not happy jan
http://www.brashboy.net/english/dualcorolla.html
The supercharger is normally pre-turbo, so you can run a larger turbo and spool it earlier.
The turbo used on the HKS twincharge kit for the 4agze is quite large, but spools nicely since it's downstream from the charger. It also runs a bypass valve to take the charger out of the loop once the turbo is on song.
      Toyota Landcruiser problems
    4. 7
      selling car
      Fuel Filter - Change or not
      2013 cruiser gxl ute
    7. 2
    8. 2
    9. 1
