How do you remove the plastic lens on the interior light, so that you can replace the bulb? I'm talking about the gen 4's.
btw...poke the screw driver on the passenger side side of the cover ...
there should be a small gap there...
ps... when removing the bulb done use a metalic object to pry it off the metal contact...
if ur not careful ull make contact with the other terminal...
even with the light switch in the off position there is still enough residual current to blow the fuse like i did last week!
if ur adventerous look into jaycar... for around $30 they have a compact mini 12 led panel (aka smd's) that comes with universal adapter bases.. fits in the roof light and gives a super bright white light... looks nice and wont flat ur battery
the boot light and glove box light can also be changed to give the old girl a new look... but then $90 could probably be spent else where... :rolleyes:
Thanks! I don't need to replace the bulb, I just want to clean the lens, there's a bug or something in there.
:rolleyes:
haha howd the bug know how to get in there and you dont... :s
Heh, maybe he used to work for Toyota :lol: Not actually sure how he got in there. But yeah I got the bug out and it's all good!
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
