Sportivo cuts out at 7k
scrolla
i am guessing if it is lift bolts that the lift wouldnt than be kicking in at all and if it was it wouldnt pull as hard as it should
but mine does pull real hard when it comes on
going by that logic, then it must be one of the sensors that are fouled. Just take it into a dealer so they can read the error codes. they should be able to tell you pretty easily which sensor is stuffed.
Could also be a dirty VVL oil filter.
what is VVL oil filter is that just normal oil filter or its another one
I took mine to Toyota today, and they said it came up with a code for vvtli, but should be ok, and on the way home the problems was still there,
so i booked it in and they said they will spend some time on it and see whats need replacing,
the got an error code relating to VVTLi and still they said it should be ok? WTF?!?
yeah thats what he told me,
that they did got a code relating to the vvtli, but they cleared it and it shouldnt come up again,
the car wasnt in the shop for no longer than 20 min, but the problem wasnt fixed at all,
so i went back as soon as realised that like on my way home and booked it in for monday,
and they said they will spend some time on it and see what needs replacing
i think they just wanna rip me off for few hundred dollars,
      Classic Toyota
    5. 30
      FUEL WARNING MESSAGE
    6. 30
      Classic Toyota
    9. 30
