Fuel Filter Location
it's not hard to replace.
The hardest part is getting the top off the old pump housing to transfer all the bits to the new filter housing. The plastic clips are pretty tough.
One thing to watch out for is the o ring that sits in the top part of the filter, make sure you get it out along with the cap that holds it in place when changing over the filter. If you lose either, you can't buy them separately, you have to buy the whole assy $$$. Obviously with no cap or o ring you're not going to have much in the way of fuel pressure.
Edited by pinzvidz
      Engine cuts out after starting occasionally.
      Prado 1997 Petrol 6 Cyl GXL - GCM Specification
    4. 2
      60 series diesel engine stutter
      Translated to English
      K&N air filter
      Sr5 rims to fit SR
      New member
    9. 1
      RAV4 2017 Apple Carplay Upgrade Recomendation
      04 Kluger tailgate/reverse camera wiring
