gutless acceleration
ok the other day i was going about 80 km/h and i dropped from 5th to 3rd and floored it
it then just cut out and jumped back in
i was like "ok..."
so drove an extra 200 metres went around a round about and it just died again and wouldnt start
i left it for 5 minutes and tryed to start it and it started and idled
then i reved it and it sucked air in and just died again
left it for 10 minutes started and it was fine
but now when i accelerate it pretty much struggles
i can feel it as i go
what is this?
looks like a piston problem...maybe the lead??? or i might be wrong all together...do u get ne warning lights on ur dash...if not it maybe jst a piston prob or faulty leads....im no expert bt thts my thought....
Edited by wishbone
sounds like a loose wire or somethin look under the hood with the engine running and wiggle all the connections, spark plug leads stuff like that if thats the problem with any luck itll cut out when your moving that part also give the disributor a bit of a whack and see if that does anything
wow really? has your oil gone all creamy? if it is indeed a blown head gasket, do NOT drive it anywhere (to state the bleedingly obvious)... mum's ford needs the head bored for that reason...
  • 1 year later...
ok
not a head gasket
it was a heater hose under the distributor that had burst and was spraying coolant onto the distributor
haha
so glad =]]
got same problem plus more atm with my hilux, seems like the distributor is causing overheatin gproblem in coil pack resistor seems ok but gets superhot to touch... any help >
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    5. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    9. 12
