adjustable cams
heys
i wanna get adjustable cams for my auto 1zzfe... has n e 1 done this for their auto rolla n if there is where can i get them from n for how much install and supply and tune with cam control .. ?
thansk guys
what do you mean by 'adjustable cams'?
you can't get adjustable cam gears as it interferes with VVTi
If you are talking about adjusting the cam timing, this can be done many ways with different ECUs, piggybacks and plug in controllers.
no they are saying that you can't get an adjustable cam gear because of the vvti. However, if you wish to change the cam timing (different to adjusting the cam gear) you can with a cam controller, but it would be pretty pointless
hmmm
coz i been givin tips that if i can get a cam controller i can pretty much get a tuner to tune it so that i can either feel all the cams working in low - midrange or at higher RPMS
If you fit a vvti controller you will still need something that can control the fuel.
i believe that the power enterprise cam controller can do air fuel settingg in it .. is dat what u talking about ?
Or you can change the physical camshaft piece for a different brand with a more aggressive profile
changing physical cam shaft meaning what ... changing the size or length ?
Neither. The cam determines such things as when the valves open and for how long. Standard cams will be for fuel economy. Performance companies make gnarly cams that will open a particular valve for longer at the right time, for example, which would make your car marginally quicker. Watch the VVTLi annimation pinned by Northy in the technical section, it's related sort of. If you change the actual camshaft you won't need any electrical crap, it's good old fashioned muslce car technology.
Changing to a more aggressive cam profile/design. Aggressive cams tend to have more valve lift, duration and overlap which moves the power band higher in the rev range. Cams can however also be chosen to target more mid range or low end depending on what you want out of the engine. There is a lot of detail in cam design and selection and this probably isn't the time or place to discuss it, but this should give a good overview on what cams do and help you decide what you're ultimately after, Wikipedia link and How Stuff Works link.
Crower offer aftermarket cam shafts for the 1zz.
thanks guys .. appreciate the help guys n das why im silver ! hahahaha xD
yeah I know....I have it :)
but the airfuel ratio isn't simple to set.
you need a wideband to check the correct ratio.
Guys tell me a brand that produces a camshaft piece for my engine (3zz-fe - european) :help:
Edited by 3zzfe
I have never looked before, but you might have to go with a custom grind. I'm sure there are some specialists that can do regrinds or new billet grinds near you.
Thought this was about camshafts not coffee :P
      1987 Toyota Corolla - 60 000km on the clock
    2. 3
    3. 3
      Toyota Landcruiser problems
    5. 13
      300 series turbo issues
    6. 55
      Stout Owners
    7. 13
    8. 8
    9. 55
      Stout Owners
    10. 2
