i want to disable the factory wireless control so i can put in a much more reliable remote control system in,and un program the remotes so nobody accidently uses them,so how do i un program them from the system programming them is easy ,but how do you do this?
im sure if you take your car to a place to have an aftermarket alarm system professionally fitted, they would be able to override the oem system, but only so that it overrides the immobiliser/alarm. they would probably still work for the door locking actuators in the central locking
  • 4 weeks later...
Hi mate, where can you find afermarket remote? Coz i just bought new remote from Southside Toyota, it was working well in 1st month, afterward, it is mulfunction. I am thinking it is out of battery as they may store it for ages.
Posted (edited)
Also, my remote is for 99' 2.2 model, and i can not find a seam to open & replace battery, does anyone know how to work it out?
Edited by jbjb
^^ Unfortunatly the OEM remotes are a sealed unit so the battery can't be replaced.
They're only about $30 from Toyota and are very easy to program yourself.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
