clutch suggestion
trd
hi guys. me again. any suggestion on clutch? i would like to modify it lighter and faster to shift? any brand suggest? if so, please post the parts numbers and brand. i was made a qoute around 1000 for exedy heavy duty clutch with standard fly wheel. is it necessary to change? how much would it be?
cheers :rolleyes:
trd
get your stock flywheel surfaced for $40 or less. The Exedy HD kit SHOULD cost a lot less than $500. Mine was $260@trade price including flywheel machining and throwout bearing.
is this for the corolla sportivo? do you have the part/kit number for the exedy hd kit for the 200-2004 corolla sportivo.
have one on my other car and found to be really good value.
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
