where to get new engine?
markie31
What's your location? In Sydney there's a place in Villawood, on River Drive near the Woodville Rd ramp that fits import Jap engines with low kms. I know they'll do a 6th gen so assume they can source a 7th gen as well. I was quoted $2,500 for a new engine including installation. (Oddly enough a recondition of the existing engine also costs $2,500.)
-Jack M
why not be different and try a 3S-GTE (ST215) from Caldina unless you Celica's build date is 1999 then ST205 :D ... hehe :P
hey guys thought i would just post it on here instead of starting new topic being im looking for a new engine for my 1987 celica which currently has the 1s gen 3S-GE engine in it was thinking BEAMS but not sure on price or if there are any mods i have to make to my engine bay or do they bolt straight in.
thanks
thanks
I like your taste, but these are incredibly expensive (supply/demand). You'll need to get it imported. You'll also have to look into the transmission since yours might not bolt up, as well as the possibility of some custom fabrication. You'd be looking closer to $5-7k than $2k.
Edited by Keisari
thanks
BEAMS = RWD. Not gonna bolt up (box should, mounts won't). If anything, just get a later generation 3S-GE, or even go a 3S-GTE.
thanks
a 3sge is a 3sge beams or not blocks the same (externally atleast) so if you can find a 3s in a front driver you can put a 3s beams in a front drive
(imagine that an sv21 with a beams engine in it (wat a waste))
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
