Does anyone have an idea how could I clean Corolla 2001 (AE112R) fuel tank?
Can I do it without taking the tank off?
Is there any hole which goes to the tank under rear seat.
I've not looked at the bottom of a 112R tank, but if you're lucky it will have a drain bung. Unscrew the drain bung and let all the old fuel etc out
If there's no drain bung then you have to clean the tank the best way anyway... Drop the tank out of the car and remove the filler neck/pump assembly etc and flush with your preferred flusing agent etc.
Any specific reason why you need to clean it? What I would recommend if you were just looking at cleaning it for the sake of cleaning is to pick up a bottle of Fuel Doctor. This stuff was originally developed for keeping fuel storage tanks clean since it is hard to do so when they are underground.
      Remote start
    5. 9
    6. 9
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
