Guys,
I recently bought a remote/keyless entry pad for my 1997 camry v6 to replace the one which is broken. Does anyone have the programming guide for it?
Thanksss
Its in the manual :) I dont have it on me atm but if you need i'll type it out to you tomorrow.
I remember posting a guide here or on TN years ago about this...
I don't remember roughly,
turn the key OFF to ACC (3x as quick as possible, with all doors closed)
then after this I THINK press the LOCK switch inside the car (near the door)
then press the remote contol.
but yeah thats all i remember.... :( sorry
You're correct...
Turn the key from off to acc 3 times as quick as possible...
The security light should stay lit up on the dash cluster...
While the light is on, press each working remote button that you own once to activate (blinkers will flash for successful activation)...
Once done, test all the remotes and make sure everything is working...
hey guys, the remote came in this morning. i managed to program it using the instruction that you gave but no luck. any idea? thanks
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
