about sunroof
Bolts needed for 1kd acessorues melbourne area
Bolts needed for hilux 1kd ftv engine finushboff bolts on can any one help -
4
Current Drain
Also if the keys are kept close to the 200 the system dose not go to sleep. Ray. -
Replacement Key for Kluger 2013
Hey guys I have a kluger 2013 KX-R (2WD). The spare key has been lost and I'm only left with 1 key at the moment which is asking for trouble I've been browsing around and would like to get a replacement from Aliexpress as the local prices from dealers etc are ridiculous. Happy to give programming a go myself On the key that I have, I can see the letter G. I've opened up the case but there are no numbers anywhere. So when I'm trying to hunt for a replacement, I don't know what chip is inside, what Mhz, and what Key cut is needed Attached is a photo of the current key/remote Any help would be much appreciated! -
4
Current Drain
Thx gents , auto elec has done all those things with no success . 👎 -
4
Current Drain
I own a 2017 vx & they come standard with only one battery the second may be an aftermarket add on I would be looking into how & were it has been wired into the system. Ray. -
4
Current Drain
Have you tried disconnecting all power either by disconnecting both batteries or disconnecting the main plug to the ECU - firewall on passenger side. -
Camry 99 cooling fans not turning on Normally
Thanks i do have one might be the relay bases etc -
No idea but I have attached the electrical wiring for the 1999 Camry. Hope this is helpful. 99CamryElectricWiringDiagram.pdf -
Hi all just joined this group fault with my old trusty 99 Camry has me a bit stuck, as iam not new electronics at all . so, the cooling fans are not turned on with normal driving, i have replaced the 2x temp switches one on the top of the motor next to the dash gauge sensor and then the one at the bottom of the Radiator. Relays are fine but for good measure these were swapped out in fault finding. When the AC is on Both fans operate just fine, so we know the ECU is getting to tell the fans when to swicth on and how much speed etc , so currently iam driving around with the AC just for the fans. My next idea was maybe a bad connection on the ECU, so that's tonight's job. But other than that anyone got any ideas or has come across this in the past ???? Cheers -
Kluger Hybrid GX 2023 Wind Noise from windows
I've noticed wind noise coming from both the driver and passenger side window glass in my Toyota Kluger Hybrid GX 2023. Took it into Airport Toyota dealership (where I purchased the car in Nov '24) and went for a test drive to demonstrate the problem. Mechanic said it was unusual and too loud even with the windows fully closed. They took in the car to investigate and was first told that the mechanic sealed the windows with tape and tested and found 50% of the noise reduced. I was told seals will need to be replaced. Now the wind noise is even louder. Next day, got a call asking to bring in the car to refit or replace the whole windscreen. Totally different to what I was told earlier. Has anyone else experienced this? I’ve come across mixed reviews on Reddit mentioning potential issues with seals under the bonnet/hood, door seals, or even the mirror design. Would really appreciate it if fellow Kluger owners could share their experiences and, if you've managed to resolve this issue, the solution that worked for you. Thanks!- kluger gx
- kluger 2023
(and 1 more)
Tagged with:
