how to reset oil/cooling lights?
1zzfewagon
Hi
just wondering if anyone knows how to reset the light on the panel .
Everytime I change oil or draining the radiator coolant ,the light comes on before you start the car.
i.e
if you change the oil the lights comes on the panel before you start.
then if you change the coolant the coolant lights comes on before you start the car.
nothing major just want to know the reset. :help:
Edited by 1zzfewagon
Is this in a ZZE Corolla? I've never had the issue your explaining :unsure:
Its not the standard lights check the car does each time you move the key to IGN2 is it?
Hi SuperDAve!!
its a 1zzfe engine and yes you are right, its just the standard lights check the car does each time you move the key to IGN2
however it remember the last DIY i made :angry:
Oil or Coolant.... must be only the dealers can clear them somehow..
Hi SuperDAve!!
Umm, those lights always come on when you turn the car to ON, just as in every car. Check engine light, oil pressure light, battery light, ABS (if you have it), airbag etc always flash on startup, it's programmed into the ECU as a quick check to make sure everything is cool. It is only if them come on whilst the engine is running that a real problem is present
The only time it might be a bit different is for oil pressure etc immediately after an oil change, it takes a few seconds for the oil to circulate so the oil pressure warning light will be on whilst the engine is running, but only for a couple of seconds or so.
Edited by Hiro Protagonist
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    4. 199
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    9. 11
      300 series turbo issues
