Stock Headunit working with aftermarket speakers?
Hi from Wagga
Engine oil dipstick reading
Landcruiser 13B Engine Swap
Hi I’m not shore how you went with this project but on a whim how did you go and do you still have the old 13b engine as I have this car and the engine failed looking for options cheers -
hi I have a 1992 RN105 22R with a G52 box, can i use an automatic gearbox from a donor vehicle (1991 4runner 3vze) and make it work in my manual ? -
Lock CH-R
Just got a used 2018 CH-R, I always have to lock the car by pressing lock twice to have the light turn off. A friend borrowed it and pressed lock only once and the battery died because all the lights were still on. Is that normal? Shouldn’t one press of lock on the key switch off everything? -
Meticulously cared for, one owner, classic 1999 Toyota CSX, 1.8L Twin Cam with less than 54K on clock. Always serviced and garaged. Full receipt history and providence available. Paintwork, seats, carpet and engine in near new condition, no rust, no accidents. (minor stone chips on bonnet). ABS brakes, driver + pass. airbags, auto windows, auto door locks, 6 CD stacker. All working. This near perfect gem, runs like a dream with power to spare, asking $6000 ONO. IMG_6776.HEIC IMG_6796.HEIC IMG_6806.HEIC IMG_6807.HEIC IMG_E6775.HEIC IMG_E6790.HEIC IMG_E6792.HEIC IMG_E6803.HEIC
