What wheel is this?
Hi all, I'm new to the forum and hoping the brains trust here may be able to help, maybe even seen the issue before. I have a 2010 Hilux KUN26 193k on the clock. I have been searching for a possible cause of a clunk which has developed which sounds and feels like backlash. It seems to be coming from towards the front of the vehicle. While the vehicle is idling along in lets say first gear and if I was to ever so slightly touch the accelerator pedal I get a clunk sound like something is engaging and then let my foot off again it happens again but like its disengaging it can felt through the car. I have had it up on a hoist and checked all the engine and gearbox mounts which all seem fine. The tailshaft and uni joints all seem fine also. The clunk happens in all gears but once cruising in any gear you wouldnt think there was an issue. Originally I was leaning towards a clutch issue but only because I was noticing it while changing gears but with further investigation I have noticed it happens without touching the the clutch pedal and just on and off accelerator. I have a throttle controller on the vehicle and thought this may be the issue so I unplugged it and nothing changed. Im hoping someone has seen this before and can point me in the right direction. -
project 2007 camry grande
The wreckers don't want to sell the centre caps , they only want to sell complete wheel sets. Toyota dealers can supply them new in a packet , but don't know if there is one in a packet or four. -
300 series HiAce van
I have a 2023 swl HiAce van. Has anyone else had trouble with the paint. I have rust coming through on different location on my roof -
Hey Mate, Im no professional so dont quote me on this, but I think that's normal. They flash when you break traction and the DAC kicks in. If it's constantly flashing at you even when you're not breaking traction, you might have a problem. But it's the same thing with traction control on newer cars. It flashes at you when the traction control is activated and you are sliding or drifting, or whatever. -
4
I'm having the exact same issue as Graham. Last time they told me it was the battery. Toyota still can't find the issue, going in for service in about 2 weeks. We'll see what they come up with this time. -
4
I’m having the same start up issue as Garry, it seems to be a problem with the accumulators that control the air flaps. I took it up with my dealer and they want $900 to replace all 6 (they have to pull a lot of the dash apart to get to the top 2 vents) and they won’t guarantee it will fix it. my car will take 50 seconds from cold start up before the climate control can be turned on and it resets to 25 degrees, if the car has been tuned off for less than an hour, it still takes 50 seconds to startup but it will automatically revert to the last temp set (say 22degrees) once that is done the climate control works perfectly other than it doesn't have air flow on the passenger side feet and I suspect its one of those 2 accumulators that is playing up. Is this what others are experiencing? I will post what I find once I find out what is the cause I think gnh-1 issue is different, that sounds more like a blockage and the system is icing up, hence the water in the cabin -
BOOT LATCH RELEASE
The boot latch release inside the car (on floor next to the driver's side) is broken. Pull it up and it is just loose and doesn't open boot. Any suggestion whether this is a diy fix or who or where to have it fixed at a reasonable price? Cheers
