Here you go guys, this is what they look like.
Upon driving with it a bit more it does reduce the body roll a fraction but like all FWD cars when you stick it in the corner the front tyres wash away which is not good. :angry:
Let me know what you think.
TRD Strut brace
I realise that bud but FWD cars will always have that against them no matter what tryes,suspension, etc etc.
Sacrifices we have to make huh! ;)
unless u have over 180kw at the wheels, wider tyres will help as there will b more grip and they wont spin very easily at all.
but i guess u will just have to learn to not stomp on the gas fully, to drive quiker.
Cheers PK ;)
When funds cometh my way I will do the TRD rear sway and maybe the member brace to tame the lil' sucker.
Still researching the best exhaust setup which is probably the number 1 priority. :blink:
from previous exhaust test/changing and dynoing..
the best i've found is a full lukey exhaust system.
high flow cat, lukey front muffler, lukey rear muffler.
I was actually casing the Magnaflow range of products as they are highly regarded in the states and proven with the 2ZZ-GE. Mind you they are pretty pricey here :angry: in OZ and if you check out their website they have some sound clips of different cars.
Magnaflow is a good & reputable muffler. but, very pricey... <_<
sounds & looks nice too. and the built quality is very good. ;)
but very very very loud on my sportivo. i changed JUST the rear muffler and it already sounds like cat-back on some other cars.
yeah, this is the one i got. it really gives off a hardcore sound. in fact it sounds a little bit like the acura rsx sample sound that is on the website.
i dun find that there is a loss in low-end torque. but i'm not too sure.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
