'96 Camry at the 1/4 mile drag strip
ASG14
Well it is TRD supercharged
AND at 6psi...
I was expecting slightly better times than that. But... that comes with practice ay? No doubt if you had a Manual and were more experienced, you could probably shave another second easily right?
^ Not a chance in hell would I shave 1s off that without more boost.
Stock the car is 16.5 or so in the 1/4. My friends were surprised how fast it was too. I was expecting a 15.0. If I get a better exhaust, upgrade my injectors, get a lightweight crank pulley, and take like 100lbs (seats) out of the car, I may just "tap" the high 13's.
Oh, it would help a LOT, but not 1s faster without more boost I don't think. 1s is a lot more then you realize. I wish I could easily break into the 13's....
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
