Whining noise
Balkanite
Hi All,
Just wondering what could be causing a whining noise in the mornings when i turn on my 2005 Camry Altise.
it only happens when it is early in the morning and after a couple of hours of use dissapears.
Any Advise?
Kind Regards
We might have a similar problem except I have an Aurion.
I get this whining noise every time I go over 3 Grand and my fiancee is in the car.. It seems to come from the passengers seat.
Hi All,
Ah-aha no unfortunately it isn't that simple,
Its still under used car warranty,
So far they have replaced the top bearing on the engine and a water pump.
The noise seems to be coming from the engine bay of the vehicle.
Any Suggestions?
  • 9 months later...
Hi All,
Any Advise?
Kind Regards
Often get those noises. Traced it only happening when the Missus was in the car? HA HA :lol:
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
