Hey guys i was on a cruise on the weekend with some other corollas an my cool air intake isnt as loud as theres i remember when i first got mine like 5months ago it was so loud now you can just hear it ... doesnt have that raw sound to it anymore? :unsure:
Option 1 if I clean it you recon the sound will come back?
Option 2 Buy a new pod? if i do whats the best an loudest pod..
Anyone got any suggestions... wat it could be or wat i should do :huh:
what pod do you have? and what CAI do you have?
check if there are leaks, and see if the pod is still good.
check if everything is still good with the install like is everything still intact?
check if your stereo is turned down?
just jokes man.. good luck with it.
Ive got the TRD Cold air intake ... an no its not just cause im use to the sound ... its not as loud as when i first had it ... it sounds like a wrexi when i first installed it lasted for a month an then 1 day it was raining really bad since then its just not as loud.. :angry:
Check the pod. It might have picked up alot of road dirt when it rained. If it's clogged up, it will be quieter.
if the above mentioned still fails....try resetting ur ECU n drive it hard (I MEAN HARD) for 200 to 300 kms......than it should be good :D
When cleaning the POD also clean the MAF sensor ;) use a brake and caliper cleaner and be careful when doing so ;)
check the silicone join where the CAI joins the throttle body as some members have had trouble witht his boot leaking.
mentioning this.... everytime it rains that means he might have to clean filter regularly?
anyone got a easy solution without removing battery to clean pod?
i guess there wouldn't be unless you work from under. but you'd still have to remove cover.
as for cleaning MAF sensor with brake and caliper cleaner... when you say carefull... be more specific?
    2. 0
    3. 1
    4. 0
      Tyre Sale Specials
    5. 10
      Android auto
    6. 0
    7. 0
      Remote start
    8. 1
    9. 1
    10. 10
      Android auto
