[WA] corolla zze headlight levelling switch, door handles, o2 sensor extension
Starter motor issues
We sell the starter motor to suit the 5S-FE on our website carusoautoparts.com.au - here is the direct link below: https://www.carusoautoparts.com.au/store-2/p/jas-starter-motor-snb034-to-suit-toyota-camry-sxv20r-1997-02-5s-fe-20l-petrol?rq=Snb034 -
Just purchased a 2024 Rogue, love it generally however. Whichever mental giant decided silver was a good colour to have on a vehicle dash needs to go stare directly into the sun for an hour or so. 🙂 The reflection projected onto the windscreen and the glare that comes off them is very distracting… Anyhow… anyone know: 1. How to get the speaker grills off the dash wart speakers? 2. If there are matt black speaker grills available from somewhere? 3. What could be done to convert these to 100% matt black that will look professional and be durable enough to sit on the dash, exposed to the sun. Thanks in advance! -
Noob here! I've got a modern Hilux with a Mountain Top Roll Cover on the back tray: https://mountaintop.com.au/products/mtr-roll-cover-to90-91?_pos=5&_sid=838d083ad&_ss=r I'd like to get a tub rack on the back like this on the cheap: https://www.4wdsupacentre.com.au/kings-universal-ute-tub-rack-3mm-zinc-powdercoated-steel-adjustable-height-width-easy-diy-install.html?gad_source=1&gclid=CjwKCAjwydSzBhBOEiwAj0XN4PZO8tXD7-IdCLidg4-yQks3Pa472OAGpoM-U650arpHAT5UlI4mJRoCHKsQAvD_BwE but I'm struggling to understand what will fit with the mountain top roll cover. Could anyone help me out? I'd like to get a rooftop tent on the rack but from what I'm seeing mountaintop don't have a solution to this. -
Does anyone know the cost of this repair? I’m pretty sure mine is outside the warranty period. I’ll book it in anyway, just curious is all. -
Do a Google search https://www.google.com/search?client=firefox-b-d&q=T-SB-160-18 Then download the file and read it. If applicable as a warranty claim, the transaxle will be replaced. T-SB-0160-18 - Transaxle Whine Noise, Harsh Shift, MIL ON, or Reduced Power .pdf The assessment cost relates to Steps 1-3 to confirm that this service bulletin and warranty claim is applicable. -
How did you go with this problem? Mine is doing something similar so I’m curious. Can I ask where you found the service bulletin? -
Adding more spotlights
I have put on a Toyota light bar on our Hilux, can I cut into the power wire to support 2 x 9 inch kings led spotlights or is that to much draw? or do I setup the supplied wire loom and hook into the high beam switch wire on light bar to switch a second relay? cheers -
GR sport tailgate seal
hey guys, new to the club, picked up a 24 GR Sport yesterday. Has a gap in tailgate and wanted to seal the canopy from dust. Does the Rouge seal work? Have tried Grunt but they don’t do one yet. -
Fuel light vs remaining range
Got a new rav4 hybrid cruiser and still 'testing'. This week tried to see how far we could go on a tank before the fuel light comes on. For the entire tank, actual kms driven + remaining range remained around 900kms. With about 790kms driven and remaining range on about 125kms, the fuel light came on but then remaining range suddenly dropped to just 25kms. This was really baffling. When we filled up to auto-stop, we added 43 litres, so I would imagine the 125kms range we had just before the light came on was more accurate. Just wondering if anyone has an explanation for the sudden drop in range?
