Camry gen 6 late 2006 front parking light globe rem?
Spider
Sorry to sound like a dummy.
Is there any link to show me how to access the globes to swap them out?
I can get to the high and low beams but the parkers are a differant kettle of fish.
Thanks again gang.
:huh:
Thanks again gang.
:huh:
You will need to partially unscrew the bumper (if u can the whole bumper but partially should also be fine), then unscrew the headlamp move it slightly forward then replace the bulbs.
Bloody hell.
Bit much ain't it?
Oh well thank you all.
No, whats the best way to take off the bumper then?
Hamfisted spider neds to know.
Thanks gang.
Sorry to waste your time.
Did an FAQ and found it.
http://au.toyotaownersclub.com/forums/inde...c=16527&hl=
Thanks again
Edited by Spider
Bloody hell.
Bit much ain't it?
Thanks gang.
Thanks again
Awsome,
Just take your time with it and you should be alright.
If possible, get someone to help you aswell :)
      ZRE182 Nudge bar
      2016 Hilux SR5 Coolant Issues
    7. 2
      What to say!
    10. 4
