stocker speaker sizes on sportvo
hi.
what are the stock speaker sizes on the sportivo f+r? and what are the max sizes i can install on the front and the rear?
think i've seen people install 6" on the front and about 4" on the back?
saw some fusion RE-CM5250 2-way 5.25" component speakers on sale catalogue from repco ($29.95 save $150 but are probably more like 80-100rrp)
so thought oh yeah pretty cheap maybe ill change the stock ones
cheers
probably wont bother with the 5" ones. ill buy some 6 or 6.5" ones when i see some good ones for cheap.
im just looking for an excuse to do something to the car. haha
Edited by hAmZ
yeah you can fit 6" ones in the front with out modifications, you can reuse the black pod on the door, but for the rears if you want 6" speakers you would have to pop off the black pod make a spacer ring and drill holes into the door to hold the speaker.
im pretty sure i fit 6.5" at the fronts.. and my rears are still stock so i cant say much there.
but im sure its about 6" cause i got 4" to install in the rear but i need to make some spacers.. there fore i cant be bothered,
      Bluetooth stopped working
    3. 3
      Corolla Seca For Sale
    5. 2
      Toyota Corolla Sportivo
    8. 2
    9. 1
      Toyota Landcruiser problems
