Avalon Timing Belt
hanofee
Hi, I just bought a used 2002 Avalon at 155K without knowing if the timing belt has been replaced or not (most possibly not yet). Toyota dealer said, it should be done at 150K. My question is more:
Is the 2002 Avalon has interference engine or not? Some page on google said that Avalon doesn't have interference engine, thus, snapping timing belt won't have any effect on the engine (rather the inconvenient that I need to get it towed-away). Is that true? Or shall I just replace it anyway?
Also, if I have to replace it, will it be better to replace the waterpump as well (as for most car, it might be more economical sense to do both at once, rather than waiting the pump to break)?
Thanks heaps.
not a teribly big job for the conveniance of knowing id get it done i mean a dealership only charges $300-$400 maybe more if requires water pump idlers and seal for wat its worth while its apart id deffinately do the seals but its up to you just remember also a tow isnt free either so $300-$400 is better the $300-$400 + tow fee
Thanks heaps.
Thats a good question hanofee,I,d be inclined to make a few enquiries regarding that because if that belt breaks and those pistons do smack the ars* of those valves (leave the rest up to your imagination).One thing I do know is that when my brother replaced the timing belt on his RAV4 it wasnt much more to get the whole kit which like you said contains a new waterpump.155kms thats almost 100,000 miles in the old money,for peace of mind put a new pump and belt on, as its sure to let you down at the worst possible time
best not to take a risk with the belt, if the service centre or dealer replaced the belt there should be a sticker or note in service book. with the 3ltr v6 the waterpump is changed at the 300k belt change.
Thanks heaps.
That's what other information said, that only interference engine will cause the pistons to hit the valves in case of timing belt broken. If it's not interference, it will just stop working without doing any damage (that's more or less how I understood from google :)))... it's not that I don't want to replace it, but I'm wondering if I can wait another month or 2, when I have more time to bring it to my mechanics. I don't use this car that much, just to go to the station daily (about 1.5 km roundtrip).
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
