In the fuel tank.
Seriously, what you need to do is look is head over to the attached link and download the appropriate service manuals. Yes it is for a Camry, but the American 2GR-FE Camry which is very similar to the Aurion. The engine related stuff is pretty much the same and it will answer probably the next bunch of questions you may want to ask:
http://www.camrystuff.com/index.php?page=Gen6_Manuals
In the fuel tank.
remove rear seat base by pulling up at the front of seat both left and right sides (with some force) there will be a plate with a wire going through it pry that up and diconnect the wiring plug to reveal the top of the fuel pump/filter assembly
When mine needed replacing i saw the Toyota Service Tech removing the back seat and changing it from there, Looks like its the same process for the Aurions as mentioned above :)
      Remote start
    2. 1
    3. 0
    4. 9
      Android auto
    5. 9
      Android auto
    6. 1
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
