Modification to 3S-GE Gen 1 engine
Norky86SX
hey guys.
I own an 1986 Toyota Celica SX, with the 3S-GE engine, and recently had the head repaired, and now im looking for some extra power.
i was thinking about forced induction, but with the 3S-GE compression ratio, i think that would be a bit dangerous... any ideas?
Edit: 9.2:1 compression ratio, turbo an option?
already done the exhaust, with extractors and a sports exhaust.
Edited by Norky86SX
hey guys.
IMO dont bother turbo-ing a 3SGE (although it can be done), just swap to a 3SGTE.
I've written an article on modifying 3SG's. it does not cover turbo conversions as i have a separate article on the turbo engines.
see it at www.roadandtrack.net.au.
Doesn't that article specifically not mention Gen1 3SGEs though?
Would it not be cheaper and give a higher turbo pressure turbo putting a 12Psi in then swapping for the Gen 2 GTE?
It might be cheaper, initially, but it will cost you more in the end (believe me!) and you can run 12psi on a stock Gen II 3SGTE if you get a boost controller for it.
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
