ABS module
SCOOTA44
Anyone noticed when the ABS does it s self check that the sound has gotten louder ? my car has done 160k. just wondering if this is a sign of wear or because its a taxi it starts up more often than the family car ?
Given that my Aurion has only done 1/3 of your Aurion's Ks it might not be a good comparison, but I'm noticing the opposite effect.
Did you recently get new pads or rotors?
yes recently changed the pads all round and they are different to the last pads installed.
did the brake fluid get replaced at the time of the pad replacement ? if so what fluid was used ?. the toyota dot 3 is suggested , the later dot fluids may cause some strange issues
Yes brake fluid changed and spoke to the mechs and they put in different pads this time. Maybe this is the cause.
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
