Removing instrument cluster
SirNed
G'day folks. Hoping someone can give some quick and easy instructions for removing the Instrument cluster on an Aurion.
As in the cowling around the Speedo. Trying to work out how to remove after the two push pins are removed from underneath the top.
Seems the individual that had it first decided to clean the plastic with a bit of steel wool. Have the panel now to change it over.
Edited by SirNed
Once you remove the two clips, the trip unclips and pulls out. If you have a look at the service manuals (linked to in the FAQ's) the 'Instrument_Panel' manual has the following diagram on page 22:
Thanks for that mate. Found the cowling around the instrument panel is held in place by the two paneels below that which is held in place by the panel underneath that as well. Strangley enough that wont come off until you take off the kick panel which is held inplace by the sill panels. So working backwards from there and all good.
      Gen 6 Cluster Backlighting Issues
    2. 0
      Hilux surf
    3. 6
      Buying a Hilux / Surf
    4. 0
      05 hiace ecu
      1989 Hilux Low Voltage
    6. 27
      FUEL WARNING MESSAGE
    7. 27
    8. 27
      Wanting to build my car.
    10. 0
      2004 hzj79 surging/jolting
