tyre pressure??
i ran 20-22psi on the strip, recommended by a mate.
hooked up pretty good!
is that all 4 or just the front??
You wouldn't really want to put your rears at a lower pressure (on a FWD of course). If anything, a higher pressure would be better.
It's all a bit of experimentation though. The type of tire plays a bit of a role in that. I've found that some like to be higher whilst others lower. Ie. I've had better results down the 1/4 (in a different car, but example still exists) with a particular tire at 39 PSI than when it was at 34 PSI.
Usually on a circuit, 40 PSI is a good starting point to work from.
just the fronts. i had 205/50/16 potenzas
35 psi had me hopping/ axle tramping through 1st to 2nd on launch
22psi was good. gripped pretty much straight away
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
