Running Amp power cable through firewall
93camryxle
I have a 1993 Toyota Camry xle that I just recently got and for a great price and deal for overall quality love it so far but I digress I'm trying to find a hole in the fire wall to run the 12v cable to run to the amp for subs if any one could help and provide pics its would be awesome thanks ahead of time!
Matt
Wait, Camry XLE? You're from the US right? Ok hmm, i am going to assume its the same, in ours there are two options the easy messy unsafe way or the hard clean and safe way. The easy way is inside the inner guard, and the hard way is through that rubber boot attached to the firewall(on the left hand side of the vehicle from the drivers seat) and down to the rear of the vehicle via the existing wiring paths. Now remember to run the rca speaker and other wires on the opposite side of the vehicle to the power cable. Hope that helps.
      maps in 2017 Camry Altise
    3. 5
    4. 4
      Front Cameras
    6. 51
    7. 51
      1kzte throttle body
      Aftermarket parking sensor
