Hi all,
I hope you guys can help me with this. I'm trying to get my car registered and I need to find where the engine number is.
The car is a 2003 Toyota Corolla Seca Hatch. The engine model is 1zz-FE.
I've attached pictures of the engine and if anyone can point out to me where it is, that would be greatly appreciated!
The second attachment is what I found on the left hand side of the engine. Is that the engine number? My mechanic told me that it should be 1zzxxxxxxx
Cheers
Ian
Your mechanic is right should be 1zzxxxxxxx
It's on the engine block facing forward where the gearbox bell housing is bolted to the engine block
Just under the water hose, to the right of the exhaust manifold, should be easy to see !
Won't be facing forwards if it's the same side as the exhaust manifold, ZZ engines have the intake at the front and the exhaust at the rear...
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
