levin ZR headlight out
Can someone give me details on those pair of so bright and white parking light, I want to change them to match the HID.
T10 6 SMD LED Cool White
Are these what's in your ZRE ? any good for a reverse light?
or you can get HID Reverse lights ;)
too expensive thought .. $140 <_<
ill get them when they reach less then or equal to $80
edit: without the spaces ... for some reason its not working ..O_o http:// m a x v i s i o n a u s .blogspot.com/2011/06/hid-reverse-light-back-lamp-system.html
Those are fitted in the front parkers only.
I believe the reverse lights are T20 's (7440), I've been holding back buying these, for obvious reasons, but might soon enough.
John, you asked earlier about the Brake Lights(T20/7440), these might be bright enough.
Correction:
Brake Lights (Outer Bulb): T15
Rear Parking Lights (Inner bulb): T10
Reverse Lights: T20
Update: I have installed these in the reverse position:
  • 4 years later...
Did anyonr actually get their globes via toyota for the cheaper values mentioned?
As i popped past two dealerships today (Adelaide) and both quoted identicsl $339.00 prices per globe. Still blows me mind that high volume manufacturer would use such ridiculous priced items (or attempt to rip their customers off)
Hi All,
I have a Corolla Levin SX 2013 and would like to change the factory globes to whites ones. I did a search  and was advised H11, however these globes dont fit this car.Could you please suggest/advise which globes to get and from where.
The existing glob is for high beam as well, so could you please advise.
VJJP.
    6. 21
    7. 21
    8. 21
