this car has had this problem since first purchased 9 years ago
oil leak at oil filter base
is just a weep but now
much more noticable
its leaking between the base of the oil filter and engine block
it has two flexiable hoses running out of the base
they are in good condition and not leaking
hopeing it will just be an 0 ring
what has to be done to fix it
Have you tried putting a new filter on lately? If so, how tight do you do it up and do you remember to put a thin film of engine oil on the gasket?
If not, when you do so, firstly apply a thin coating of new engine oil to the gasket and make sure the mating surface on the engine block is clean. Then when you tighten it, from the moment the gasket appears to make even contact with the engine block, you just have to turn the oil filter another 2/3 to 3/4 of a turn tighter. The box the oil filter comes in would most likely specify this.
Then see if it leaks again after all that. I know it may sound a bit basic, but it's not something I would rule out completely.
Edit: I realised what Hiro has said below. I was basing my post on the assumption that it could be closer to the filter side of things due to the way the question was worded.
Those two hoses will be for the oil cooler. Is it for the AE82 in your profile or another car? Some cars pump engine coolant through the sandwich plate to act as an oil cooler, others draw oil from there and send it to a mini radiator at the front of the car, so it could be either oil or coolant lines depending on which car you have
I'm assuming the car has been regularly serviced over those 9 years, so you can basically rule out the o-ring on the oil-filter itself as a culprit, so it'll come down to the oil cooler sandwich plate, whatever seals it has, and how the hoses connect to the fittings. Wouldn't be too hard for a mechanic (or a home mechanic) to diagnose and fix, nor should it be that expensive (as long as you don't have to remove the engine to machine mounting faces etc).
By the way, how have you managed to get through rego for 9 years with an oil-leak? Most places I go to crack down fairly hard on that kind of stuff, especially oil (as it creates a hazard for other road users in sufficient quantity)
if its a 5s (which it would be assuming its a 4cyl
pull the oil cooler off and replace the oring underneath, it should fix it.
no yearly inspections here... woo!
Posted (edited)
thanks for all the information and feedback
didn't know about the oil cooler bit
the oil leak is between the oil cooler.
and the engine block
oil filter not leaking at its seal
its a weaping leak not a drip type leak
so thanks to everyone
it has to be the 0 ring under that oil cooler
will degrease the area again
then fix it
Edited by dirty hands
  • 4 weeks later...
Posted (edited)
found this oil cooler pic
its leaking at the gasket and o ring below the oil cooler
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
