I have 2 K&N filters to choose from, which is better yous think? Can't get the XStream K&N cuz i only get these 2 to choose from.
Will be changing the TRD filter to K&N. Is the filter the bigger the better? If so the straight design K&N has a bigger filtering surface area.
This one is 1 inch shorter and has a funnel and is tapered in design. Uses 20ml of K&N oil.
This one uses 34ml of K&N oil so has a bigger filtering area but is straight.
The first one is the better of the 2.
I thought so too but why? Is it because it is tapered in design and having a funnel provides more air flow, less air pressure drop etc.? But its got less filtering area though, does that matter?
Posted (edited)
Post edited, i have swapped the 2nd one for the 1st with the funnel :P how indecisive but after seeing the 1st filter in the flesh it looks alright and i was assured its not too small for a 1800cc motor cuz V8s use them. Its actually wider than the straight pod so makes up for lost height, plus the funnel doesn't extend too deep down into the filter.
Edited by ZEEROLLA
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
