Unichip for a Sportivo
power 'chips' are a waste of time and money IMO.
Get yourself a nice intake, set of headers and exhaust and you will see much more of a power gain.
If you are after a piggyback ECU get something like an emanage ultimate, or go full standalone and get a PowerFC or equivalent.
Yeh i have been looking around for a Cold Air intake but was just curious about the chips as i have seen couple of people on the forum with the chips in em. And i think a exhaust doesnt sound too bad either.... Hopefully in the near future should have a cold air and a exhaust done.
Hey was wondering if anyone knows where i can get a unichip for my 03 sportivo and if anyone knows how much power u gain throught em..
Make sure you can CAI + catback + header before putting unichip
Please search in this forum for the same question, someone did a unichip on sportivo before
I do not have a sportivo, but I have ordered a unichip an waiting for delivery, and I can tell you the difference later
I have a unichip in my car which was put in by the previous owner.
I did intake, headers and exhaust first and then did the unichip. this was done years ago before there were other viable options for replacement ECUs. I think I have scans of dyno runs before and after the ECU change and there is a small power gain, but a much smoother curve.
If I find them, I will try to post it up
hey was just looking at Power Fc on this website and its doesnt say anything about Corolla Sportivo but does have a Celica with a 2ZZ-GE was wondering if anyone knows if its the same for both the celica and the sportivo.. Thanks
Heres the dealio:
The PowerFC is built for the 7th Gen ZZT Celica, which had the 2ZZ-GE engine. The Sportivo Corolla, despite having the same engine, has a different ECU and Loom stock. You can still use a PowerFC from the Celica but you need a custom harness so you can run the stock ECU as well to keep everything working happy.
SuperDave on here makes the harnesses.
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
